rdt40ish
May 27, 2021Aspirant
RBS850 Compatible Satellite model options
I have the RBS850 router +1 satelite option. i need to get another satelite. can i use other models or do i have to same model satelite? easy question i presume but didnt find my answer "yet" i...
May 27, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
You can use RBS7 or 8 series RBS. You can use EX or EAX series extenders as well.
Thank you.
