facest
Jul 12, 2024Tutor
RBS850 electrical interference
I've been suffering with an issue causing my monitor to flicker for the past few months and have been avoiding fixing it because it's a pain and I figured it was a noisy power or speaker cable, but h...
Jul 12, 2024Guru - Experienced User
Any wifi router or system can cause some noise or interferences. Find some good shielded cabling and maintain a good distance between the wifi sources and cabling or devices. 3-6 feet in between is recommended.
Can try turning down the power output on the RBR as well:
Under Advanced Tab/Advanced Settings/Wireless Settings
