facest
Jul 12, 2024Tutor
RBS850 electrical interference
I've been suffering with an issue causing my monitor to flicker for the past few months and have been avoiding fixing it because it's a pain and I figured it was a noisy power or speaker cable, but h...
Jul 12, 2024Guru - Experienced User
Is it on the same outlet?
I had a RBS50 that would cause subwoofer noise when connected to the same out let as my subwoofer.
Tried multiple cables/shielding/power and it didn't matter.
So I used that satellite elsewhere.
