dklimas
Dec 15, 2022Apprentice
RBS850 ethernet backhaul connected to switch results in loop warning light on switch
I've been having internet connection issues for some time now. I've done a lot of troubleshooting for various things over the last couple months or so after updating firmware. I have now discovered t...
Dec 15, 2022Guru - Experienced User
You really didn't give us much info other than you have an 8 series orbi and a switch.
What switch is it?
How do you have everything wired?
It should go modem/gateway into the RBR850's wan port. Then from the RBR850's lan port to switch/satellites.
