dklimas
Dec 15, 2022Apprentice
RBS850 ethernet backhaul connected to switch results in loop warning light on switch
I've been having internet connection issues for some time now. I've done a lot of troubleshooting for various things over the last couple months or so after updating firmware. I have now discovered t...
dklimas
Current Firmware V4.6.9.11
Arris S33
All external ethernet Cat7 double shielded except for what was installed in the house when built. Looks to be Cat5e.
Switch Qnap QSW-1108-8T
Dec 15, 2022Guru - Experienced User
So you're going S33---->rbr850 wan port----->switch------>satellites?
One thing to try is power off the satellites for a short period of time after the router/switch boots and then boot them up.
I've seen it with mine where it'll establish a wireless backhaul first and then the wired. Maybe if they boot up after the router/switch, the wired backhaul will default to that.
- dklimasDec 15, 2022Apprentice
Yes. I only started having connection issues after the V4.6.9.11 update. I assumed it was understood that everything was connected properly, I apologize if that wasn't clear.
I have powered down everything countless times since updating. But I'm not sure at what point this loop light was on.
I'm guessing this issue is what's causing my log in credentials at work to be locked after using the VPN for work.
I will try to power down again, waiting a few moments before powering up the satellites.
Another interesting thing is that the particular satellite that is having the issue is stuck in "please wait a moment" when looking at firmware update page. Which doesn't allow me to update the other satellite or router. I'll eventually try the manual route I guess.
- FURRYe38Dec 16, 2022Guru - Experienced User
If the RBS hasn't been updated, then you'll need to update the RBS first to be sure that it's got same version of FW. This maybe causing the loop led on your switch. If you can get access the RBS web page, then manually update it there.
Also there is newer version of FW available as well:
If you choose to update, be sure you update the RBS first then RBS lastly.
