jmclh
Mar 23, 2023Aspirant
RBS850 Firmware problem V3.2.15.25 to V4.6.14.3
I have and RBK850 router and one satellite running well on V4.6.14.3 firmware. I bought an additional satellite which is running V3.2.15.25 and everything appears fine.Both satellites are connected t...
- Mar 23, 2023
I would try manually updating it to the latest. You can download it and log into the satellites ip address and manually update it. I've done it numerous times and never had an issue
Mar 23, 2023Guru - Experienced User
- jmclhMar 23, 2023Aspirant
Thanks i will do that
- jmclhMar 31, 2023Aspirant
I have done as you suggested and the problem is solved. Thank you.
- FURRYe38Mar 31, 2023Guru - Experienced User
