TerjeSly
Feb 19, 2023Aspirant
RBS850 Fixed IP
How can I fix (lock) the ip on client wifi? I have an RBS850 and have to have the same IP on my iPhone every time it is on the network.
Mikey94025
Feb 19, 2023Hero
TerjeSly wrote:How can I fix (lock) the ip on client wifi?
First, turn off the iPhone's "private address" feature that randomizes its MAC address for when it is connected to your wifi network: https://www.techrepublic.com/article/how-to-manage-or-disable-mac-randomization-in-ios-and-ipados-14/
Next, use orbilogin.com (same as routerlogin.net) to set a Reserved IP address for your iPhone: https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router. The Orbi is still responsible for assigned IP to your iPhone via DHCP but will always assigned the same one.
- michaelkenwardFeb 19, 2023Guru - Experienced User
Good call. I forgot that. Maybe that is why TerjeSly asked the question.
More on the iPhone thing here:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
Could be that turning off "private address" might remove the need for a fixed IP address.
- TerjeSlyFeb 20, 2023Aspirant
Thanks for reply. Will test when I come to the cabin next time. I have a Homey that controls a lot of lights, heat and other things and use iPhone with presence to control functions in Homey, but then I have to have the same IP every time.
