LBnKC
Nov 03, 2024Star
RBS850 Incorrectly Connects Powerline Adapter as a Backhaul on Power Failure
I have an RBR850 and multiple RBS850 satelites. One of my satelites has a TP-Link Powerline WiFi Extender plugged into the Ethernet port. This works to use Ethernet over Power Line to get a network...
CrimpOn
Nov 03, 2024Guru - Experienced User
If there was a computer connected to the satellite using Ethernet, would the satellite think, "ah. there's my backhaul link!"
No. If there is an Orbi router connected to the Powerline network, then the satellite would recognize it as backhaul.
No router: no backhaul link.
Do these power outages last longer than some small UPS would power the router and each satellite?
- LBnKCNov 03, 2024StarWell, that’s a crapshoot. What I know for sure is that the box its all in is a weatherproof box (outdoors) and I have no room for a UPS in the box and it would not survive outside without taking on another problem after solving the first. 🙂
I found a delay relay that will fit in a knockout: RIBTD2401B. Unless I come up with another idea today that seems like my best bet. The other option is a DIN box in addition to the one with the Satellite in it, and using something like this:
https://a.co/d/c5mfl7J- CrimpOnNov 03, 2024Guru - Experienced User
So, if the satellite is NOT connected to whatever is inside the safe through a Powerline link and there is a power outage, then the satellite connects to the router over WiFi as expected?
What else is connected to Powerline?
- LBnKCNov 03, 2024StarSatellite > Ethernet > TL-PA8010P > electrical line > TL-WPA8631P > WiFi device in safe.
Yes, the Satellite does fine if I unplug the Ethernet cable and let it fully boot before connecting it again.
