LBnKC
Nov 03, 2024Star
RBS850 Incorrectly Connects Powerline Adapter as a Backhaul on Power Failure
I have an RBR850 and multiple RBS850 satelites. One of my satelites has a TP-Link Powerline WiFi Extender plugged into the Ethernet port. This works to use Ethernet over Power Line to get a network...
CrimpOn
Nov 03, 2024Guru - Experienced User
If there was a computer connected to the satellite using Ethernet, would the satellite think, "ah. there's my backhaul link!"
No. If there is an Orbi router connected to the Powerline network, then the satellite would recognize it as backhaul.
No router: no backhaul link.
Do these power outages last longer than some small UPS would power the router and each satellite?
LBnKC
Nov 03, 2024Star
Well, that’s a crapshoot. What I know for sure is that the box its all in is a weatherproof box (outdoors) and I have no room for a UPS in the box and it would not survive outside without taking on another problem after solving the first. 🙂
I found a delay relay that will fit in a knockout: RIBTD2401B. Unless I come up with another idea today that seems like my best bet. The other option is a DIN box in addition to the one with the Satellite in it, and using something like this:
https://a.co/d/c5mfl7J
