LBnKC
Nov 03, 2024Star
RBS850 Incorrectly Connects Powerline Adapter as a Backhaul on Power Failure
I have an RBR850 and multiple RBS850 satelites. One of my satelites has a TP-Link Powerline WiFi Extender plugged into the Ethernet port. This works to use Ethernet over Power Line to get a network...
CrimpOn
Nov 03, 2024Guru - Experienced User
This note on the Amazon description of the TP-Link product gives me concern:
I have not yet found an actual User Manual for this product. There appears to be software for different operating systems to set up and manage the device. Perhaps there is a setting that might say, "Turn off the OneMesh feature on this device."
LBnKC
Nov 03, 2024Star
You may be on to something there. OneMesh was off, but I poked around and I see a way to turn DHCP off vs. automatic. Maybe when it comes up and cannot get an IP it turns on DHCP. I’ll try that tomorrow and report back.
- CrimpOnNov 04, 2024Guru - Experienced User
Hope you have been able to disable DHCP on the TP-Link and see what happens.
There is a very real possibility that the satellite has accepted the DHCP offer from the TP-Link and is "stuck" trying to sync with the router. My reasoning is as follows:
- The satellite "knows" that the router is the DHCP server. (Correct for 99.9% of residential users, but not 100%.)
- When a satellite powers up, it broadcasts a DHCP request through every port (WAN, LAN, WiFi, perhaps even the WiFi backhaul channel) It accepts the first DHCP offier it gets.
- When the router is the only DHCP server, then the satellite may get the same IP offer through both a 'wired' and a 'WiFi' pathway. It can now communicate with the router.
- When the satellite gets a totally different offer from the TP-Link:
- It now believes it has an IP address that may not be compatible with the router LAN subnet at all.
- It cannot communicate with the router, not over the Ethernet link and not over any WiFi link.
- LBnKCNov 04, 2024StarYou’re probably right. Since this does not have bridge mode (that I can find) disabling DHCP pretty much killed it.
I’ll just delay startup and call it good. - CrimpOnNov 04, 2024Guru - Experienced User
I would think that if the TP-Link does not perform DHCP, that it would send the device broadcasts "up the network" until the Orbi DHCP server responded. I do not know how long devices keep asking for DHCP when they do not get a response. (hmmm one more thing to research).
- LBnKCNov 12, 2024Star
Closing this out. It does indeed seem that the Power Line Adapter was seen as a "wired backhaul" and I was not able to configure my way out of it. I put a time delay relay on it, set for 6 minutes, and the Satellite now correctly connects to the wireless backhaul before the Power Line Adapter comes up.
All is well, just a few more bucks. 🙂
