ssgtweasel
May 16, 2022Guide
RBS850 is now V4.6.8.2 however latest firmware on support is 4.6.3.16???
My RBR and RBS 850 seem to have a higher firmware than what is posted I believe the V4.6.8.2 was either auto updated or an iphone app usage updated to V4.6.8.2 What is truly that latest firmware...
May 16, 2022Guru - Experienced User
Are you experiencing any problems with v.2 loaded? If not, don't downgrade. NG is aware of the issues and has a patch that seems to be forth coming for those that can't access the RBRs web page after there systems were updated. This only effects those users. If your system is working and is accessible, leave it alone for now.
If your system is not accessible and you don't want to factory reset it, contact NG support with your product serial number and they'll fix it for you.
What is truly that latest firmware as of 16May22?
