AstroCat
Jul 21, 2021Star
RBS850 losing IP access
After some random time after power cycling I lose the ability to access either of my RBS850s (1 wired, 1 wireless) through IP. The overall system is working. I get this error: This site can’t...
Jul 21, 2021Guru - Experienced User
How are the RBS connected, wireless or wired, too the RBR?
AstroCat
Jul 21, 2021Star
FW: V3.2.18.223 (beta) on both satellites and the router.
No, just a power cycle.
1RBS is wired and the other wireless.
We had the Wifi5 version prior to this, same setup, but never encountered this issue.
It is strange because we can access both satellites right after a power cycle, but at some random time after we lose access and get the error.
- FURRYe38Jul 21, 2021Guru - Experienced User
I recommend trying a full factory reset and setup from scratch.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQI see you posted about this over in the beta forum. Will continue there as well.
What browser are you using?
Be sure to clear out all browser caches during the factory reset.- AstroCatJul 21, 2021Star
I will try factory reset. But what's also telling is that after I lose IP access I am no longer able to see which wireless connections each satellite has. Not in the app or webpage for the router. So the router is losing some kind of overall access to the satellites.
I've tried multiple browsers and systems, same issue all around.
I see you posted about this over in the beta forum. Will continue there.
