SG2010
Feb 08, 2023Aspirant
RBS850 Missing Connected Device
I just upgraded my RBR50 to RBR850. The setup was easy but in connected devices, I couldn't see any of the PC that's connected the my Satellite (RBS850). It only happened to wired PCs only. The PC...
CrimpOn
Feb 08, 2023Guru - Experienced User
Sometimes it is useful to contrast the Orbi 'app' "Connected Devices" with the Orbi web management interface "Attached Devices".
See page 103 of the User Manual: https://www.netgear.com/support/product/rbr850.aspx#docs
Could you see if they match? (or do not match)
- SG2010Feb 08, 2023Aspirant
I did try both with app and web, the number of devices in web matched the number of devices in app.
i.e. I still don't see the 2 "wired" PC in connected Device.
The reason why I need to see them is because I want to give them "reserve" IP so that I can port forward easily.What I don't understand is that if both PC got an IP from the router, how come the router don't see the PC.
And seems that it only happened to wired PC as if I use WIFI on the same PC and disable the NIC, I can see the PC in connected device in both place.
- CrimpOnFeb 08, 2023Guru - Experienced User
If these are Windows PCs, open a command window and type the command
ipconfig
This will display information about each of the network adapters, including the IPv4 address.needed for the LAN Setup table.
ipconfig /all will display much more information, including the hardware MAC address which is also required for the LAN Setup table.
Knowing the IP address, there is no device in the Attached Devices display with that IP address?
I didn't use IP Config, but I click the Network in Control Panel and I was able to found the machine name, MAC and IP from Windows and I was able to reserve the IP by typing them in manually.
One thing strange is that for 1 of the PC, when I entered the IP, it did try to auto complete it for me for the MAC and Computer name. where as the other PC didn't but neither of the PC can be displayed in attached/connected device table.
Again unless I use WIFI... as for OS, one PC is with Window 11 and one with Windows 10.
