ShmulikTal
Jul 12, 2024Aspirant
RBS850 not detected by router
My network includes one RBR850 + one RBS850 which came in one package, I later added another RBS850. The new satellite was added successfully to the network. The router and satellites are connected...
- Jul 12, 2024
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Jul 12, 2024Guru - Experienced User
Does this show as offline on the RBRs web page as well? Or just in the Orbi app?
What CAT# LAN cables are used to connect the RBS to the RBR? CAT6 is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
ShmulikTal
Thanks,
I'm unable to access the RBR850 from the webpage, Browsing to orbilogin.net or 192.168.1.1 fails to connect, so my only access is via the app. The ip address for the router in the app is 10.0.0.1.
My house is routed with CAT6 cables and the RBS is connected to the switch with CAT6.
My house size is 350 sqr meters (about 3500 sqr feet) and I have 3 floors, the router is connected on the ground floor, with one RBS installed in the basement and on on the second floor.
- FURRYe38Jul 12, 2024Guru - Experienced User
Can you access the RBRs web page at 10.0.0.1?
- ShmulikTalJul 12, 2024Aspirant
I can ping 10.0.0.1 but I can't access the webpage on this address
Sounds like there is a router at the ISP modem or ONT that the RBR is connected too.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Going to recommend that you factory reset the Orbi system, RBS and RBR and setup from scratch using this PDF procedure:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
