ShmulikTal
Jul 12, 2024Aspirant
RBS850 not detected by router
My network includes one RBR850 + one RBS850 which came in one package, I later added another RBS850. The new satellite was added successfully to the network. The router and satellites are connected...
- Jul 12, 2024
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
ShmulikTal
Thanks allot, yes the ISP fiber optic modem includes a wifi router. I live in Europe, so probably the model is not relevant.
I will try factory reset for all the ORBI gear.
Jul 12, 2024Guru - Experienced User
Couple of options,
- ShmulikTalJul 15, 2024Aspirant
Thank you very much for your help, you pointed me at the right direction and I've managed to solve the problem The problem, was that my switch that connects all ethernet cables in my house was connected to the ISP router, this created a separate network for the Ethernet (via the ISP router) and the WIFI (via ORBI). I connected the switch to the ORBI router and now it recognize and connects to all the satellites. It also solved an issue I had with my new Apple TV messing with my HomeKit accessories, because it was on a different network than the accessories.
- FURRYe38Jul 15, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
