MCK44
Dec 31, 2023Aspirant
RBS850 not showing on network map - guest wifi not connecting
i have the ORBI RBR850 with 2 RBS850 satellites, one is connected by ethernet cat-5 through a Frontier modem/router. it was working perfectly until i switched from Xfinity cable to Frontier fiber o...
CrimpOn
Dec 31, 2023Guru - Experienced User
Yes, do not connect the Orbi router LAN port to the Frontier device and one of the satellites to the Frontier device.
Go back to using the switch to connect the Orbi router and Orbi satellite.
When the Orbi satellite is connected to the Frontier device, it will get confused because the Frontier creates one LAN subnet and the Orbi creates a different LAN subnet.
- MCK44Jan 01, 2024AspirantThanks so much for your reply. I tried to connect directly from the Frontier Optical Network Terminal (ONT) where the fiber internet enters my home to power the fiber network, into the switch, but I don’t get an internet connection. Do I need to have a modem in between? Can I accomplish this myself or do I need to engage Frontier tech support? Thanks again
- CrimpOnJan 01, 2024Guru - Experienced User
ONT --> Orbi router --> switch --> satellite & other devices.
The switch cannot connect directly to the ONT.
- MCK44Jan 01, 2024AspirantThank you, I still don’t get an internet connection going directly into the ORBI router from the ONT. I unplugged/ restarted both. Any thoughts?
