MCK44
Dec 31, 2023Aspirant
RBS850 not showing on network map - guest wifi not connecting
i have the ORBI RBR850 with 2 RBS850 satellites, one is connected by ethernet cat-5 through a Frontier modem/router. it was working perfectly until i switched from Xfinity cable to Frontier fiber o...
MCK44
Jan 01, 2024Aspirant
Thanks so much for your reply. I tried to connect directly from the Frontier Optical Network Terminal (ONT) where the fiber internet enters my home to power the fiber network, into the switch, but I don’t get an internet connection. Do I need to have a modem in between? Can I accomplish this myself or do I need to engage Frontier tech support? Thanks again
CrimpOn
Jan 01, 2024Guru - Experienced User
ONT --> Orbi router --> switch --> satellite & other devices.
The switch cannot connect directly to the ONT.
- MCK44Jan 01, 2024AspirantThank you, I still don’t get an internet connection going directly into the ORBI router from the ONT. I unplugged/ restarted both. Any thoughts?
- CrimpOnJan 01, 2024Guru - Experienced User
Spectrum does not require users to log into their network. (They use DHCP protocol.) I do not know about Frontier fiber. This might be a good time to call Frontier technical support and ask, "how do I connect my WiFi router to your service?"
