fangruoyuan
Apr 19, 2021Guide
RBS850 OEPN 5G WIFI
I got one new rbk852 and one new rbs850 on sunday(RMA,NG support said it might be a hardware issue). I set orbi as AP mode( two satellite wireless connect the RBR850) Every is all right. Once your O...
Apr 19, 2021Guru - Experienced User
So did you remove the special character from the PW and what were the results?
Try a simple 6-15 alpha character only password to see if the RBS completes and syncs correctly with correct security status?
I don't use special characters on mine.
You'll need to contact NG support about what your having problems with.
Good Luck.
