WDxDangermouse's avatar
Mar 11, 2021
RBS850 only 2 when i have 3
Hello.. I installed 3 Orbi set.. One connected to my modem, and the other 2 around the house. When I log into the Router admin mode on my desktop it only shows 2 units under connected Satallites... Is this normal for Orbi or should it show all three? Being called Satellites, I assume its correct, but you never know :)
Cheers
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
  • FURRYe38's avatar
    Only the two RBS will be displayed in the Satellite section of the RBR. The RBR is not a RBS.
  • schumaku's avatar
    schumaku
    Perfectly normal - the router itself is never a connected device. Satellites, mobile phones, wireless notebook, tablets, ... are among many others.
