Pip1963
Feb 11, 2023Follower
Rbs850 Orbi just want add a further Ethernet port to another room
Hi I have a Orbi rbs850 system with 1 router 2 satellites which works great. I don’t want to add another satellite in my music room as WiFi is good but I need an Ethernet port. Can anyone recommend a ...
- Feb 11, 2023
You could just pick up a cheap wifi extender with ethernet. yes it creates a separate network but if you have nothing connected to it other than the wired device, it isn't going to create issues.
michaelkenward
Feb 11, 2023Guru - Experienced User
Pip1963 wrote:
..... I need an Ethernet port. Can anyone recommend a product I can add to the Orbi that gives me a port but does not create a separate network ?
Is that an Ethernet connection to the main router?
You could try Powerline Ethernet. This turns your mains circuit into an Ethernet network. The quality depends on the mains circuit.
