Spriggan's avatar
Spriggan
RBS850 Orbi Satellite - Power LED light Solid Amber. Will not factory reset
Hello,  Wondering if someone had resolved this same issue.  I couldn't find an answer anywhere else.    Bought the RBK852 back in Dec 2019 and both the router and satellite worked perfectly, until...
  • FURRYe38's avatar
    Oct 20, 2020
    What happens if you swap in the power adapter from the RBR temporarily?
    Possible the RBS is faulty and needs replacing if a reset or power adapter doesn't resolve...
