Spriggan
Oct 20, 2020Aspirant
RBS850 Orbi Satellite - Power LED light Solid Amber. Will not factory reset
Hello, Wondering if someone had resolved this same issue. I couldn't find an answer anywhere else. Bought the RBK852 back in Dec 2019 and both the router and satellite worked perfectly, until...
- Oct 20, 2020
What happens if you swap in the power adapter from the RBR temporarily?
Possible the RBS is faulty and needs replacing if a reset or power adapter doesn't resolve...
Spriggan
Hello again,
Thanks for the reply and idea. Switched power adapter from the router to the satellite, but the power led remained solid amber. Left it that way for five minutes, thinking that maybe it would need to do stuff in the background or something; still amber. Got a paperclip and held the reset down for a minute, but that still didn't do anything.
I guess if there is nothing else, i'll have to see about getting it replaced.
Thanks again for the assist.
Oct 20, 2020Guru - Experienced User
Contact NG support for RMA options if you don't have place of purchase options.
Good Luck
