zen0701's avatar
zen0701
RBS850 Orbi satellite's ring LED doesn't work
The Orbi satellite's ring LED doesn't work. AC adapter plugged in power LED indicator turned on. Performed reset to default, the Orbi satellite's ring LED still doesn't work.
  • FURRYe38's avatar
    Disconnect the RBR from the ISP modem/ONT. Conect 1 wired PC to the LAN port of the RBR. Disconnect all other LAN cables from the RBR.
    Press the back reset button for 15 seconds then release. Observe the front LED. Does it turn ON and start blinking?
