HoraceChan
Mar 22, 2022Aspirant
RBS850 out of sync backhaul
Hello All, i recently bought a new RBS850 Satellite-2 below and connect to my current RBR/RBS Sat 1 mesh. However the backhaul status of the new RBS850 Sat-2 is always out of sync and no devices coul...
Mar 22, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try connecting the one RBS to the back of the RBR via ethernet cable and see. Turn off the other working RBS.
You might review this as well:
HoraceChan
Thanks a lot for quick response and much appreciated FURRYe38.
HC> Not sure
HC> 1000 sq feet. 4 rooms with thick concrete walls
HC>Now it is 10 feet. I tried to put it in a number of places within my home but still failed. i.e. backhaul status out of sync and no device can connect except via ethernet directly
HC>Will try tomorrow.
The ORBI mobile app shows it as "green" but no device connected to it. Again is this new one faulty as i login its admin page but always looping for status update?
Should i try to upgrade the firmware of all ORBI first? but if i cannot access the new one how can i upgrade its firmware?
Thanks again!
- FURRYe38Mar 22, 2022Guru - Experienced User
IF you can get the RBS connected to the RBR via ethernet, update the RBS using its' web page. Update the other RBS as well. If you can get the RBS updated with FW, then update the RBR lastly.
- HoraceChanMar 23, 2022Aspirant
Hello FURRYe38
i tried but failed to get the status of the satellite. Screenshots below.
- FURRYe38Mar 23, 2022Guru - Experienced User
Can you select the Firmware Upgrade section on the RBS web page at all?
