VerneArase
Oct 13, 2021Apprentice
RBS850 Out of Sync error
Lately, whenever I reboot the router my living room satellite comes up "Out of Sync" - I need to go over and power it down and back up to get a "Good" status. This node has been problematic in th...
Oct 13, 2021Guru - Experienced User
Usually a good power OFF of the RBR and RBS takes care of that from what Ive experienced. Or a remove the RBS from the RBRs web page, factory reset the RBS and manually re-sync it. Give it like 5 minutes after it reconnects.
Dd852
Oct 13, 2021Luminary
Furrye38's suggestions are precisely what I've done in the past with an out of sync satellite. I had bought the one satellite 850 version, then bought a second satellite and that one has always been a bit problematic. But a factory reset followed by a manual resync seems to have kept it nicely stable.
