moonwatcher64
Feb 05, 2024Luminary
RBS850 Password & Orbilogin Confusions - Could use some help please?
Morning all. Have an RBS850 and 4 sats which work a treat. But I need get web page login to the router to change some 2.4Ghx channel settings .... as advised by component supplier. Trouble is for...
- Feb 05, 2024
To set up password recovery: https://kb.netgear.com/24220/How-do-I-recover-my-NETGEAR-admin-password-using-the-password-recovery-feature
Launch an Internet browser from a computer or mobile device that is connected to your router’s network.
Type http://www.routerlogin.net or http://www.routerlogin.com.
A login window opens.
Enter the router user name and password.
The user name is admin. The default password is password. The user name and password are case-sensitive.
The BASIC Home screen displays.
Select ADVANCED > Administration > Set Password.
The Set Password screen displays.
Select the Enable Password Recovery check box.
Select two security questions and provide answers to them.
Click the Apply button.
Your changes are saved.If this fails, then you'll need to factory reset and setup from scratch using a web browser:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Feb 05, 2024Guru - Experienced User
- moonwatcher64Feb 08, 2024Luminary
Apologies for the slow reply from my side to your posts. They are really helpful and I've printed them off to read and work though.
An unexpected bout of illness has meant I'm behind on this sorry but thought I'd best write to say it's not forgotten and will be worked through .... fingers crossed this coming weekend.
Thanks for taking the time with both posts and solutions and I will be back to you asap.
- FURRYe38Feb 08, 2024Guru - Experienced User
Sounds good. Take your time and get better. Have a good week.
- moonwatcher64Feb 25, 2024Luminary
Apologies for the delay getting back to you. Today I got chance to follow the steps you kindly sent and they worked like clockwork .... the reset, the rebuild and well, everything ... absolutely by the numbers.
I also followed your guide on the FW update and that also went perfectly, 100% perfectly. What a good way to spend a Sunday afternoon. I feared the worst but I need not have .... I now have a perfectly up top date system that I can actually access. I even bothered to do some proper device and cable labelling .... how many years has that been waiting to be done? 😁
Many thanks for taking the time. the instructions and guides saved me a ton of time and pain. All the best
