Brownds
Sep 16, 2020Tutor
RBS850 Phantom MAC address appearing/disappearing from LANwith same IP as Satellite
I have RBK853 (1 x RBR850 & 2 x RBS850) + 1 x additional RBS850 satellite. All satellites are Cat 6 cabled direct to RBR850 router, All devices on same firmware version v3.2.16.6 and have been fact...
Sep 16, 2020Guru - Experienced User
What is the mfr and model# of the main host router the RBR is connected to?
What is the Mfr and model# of the ethernet switch in the configuration?
Where is the swtich connected? Between the RBR and RBS?
What browser are you using?
Please provide a screen capture of that your seeing. Use the Choose File button to attach the capture file.
- BrowndsSep 16, 2020Tutor
Draytek Vigor 3910 Router WAN port is connected to a Virgin Media Hub 4 (in Modem Mode) - Gig1 Service
Draytek Vigor 3910 Router WAN failover is connected to a Netgear 6400 AC1600 VDSL/ADSL Modem (in Modem Mode), BT 64Gb service
Draytek Vigor 3910 Router WAN failover load balancing, connected to USB LTE Modem, Virgin Mobile 4G Unlimited Data
RBR850 iNet port is connected directly via Cat 6e Cable to a 2.5Gb LAN port on Draytek Vigor 3910 Router
Draytek Vigor 3910 Router - Latest Firmware
Draytek Vigor G2280x Managed Switch - Latest Firware
The RBS's are direct cabled via Cat 6 cables to the RBR, all 1Gb links.
The RBR is connected via its iNet Port directly to the Daytek Vigor 3910 via 1m 2.5Gb LAN link
The G2280x switch is connected directly to the Draytek Vigor 3910 via 1m 10Gb SFP+ cable
Various browsers ... MS Edge, MS IE, FireFox or Chrome ... all latest versions vailable
- BrowndsSep 16, 2020TutorThese are when the phantom MAC address has gone online/offline and has the IP address of 192.168.1.6. The actual satellite assigned 192.168.1.6 has not dropped our of the mesh network so far today!
- FURRYe38Sep 16, 2020Guru - Experienced User
Have you set up IP address reservations for the RBR and RBS on your host router? Something to try and see if this changes any behaviors.
I presume you are using Dynamic AP mode vs Static IP addressed AP mode on the RBR?
