absolutben
Sep 14, 2022Aspirant
RBS850 Pulsing White At night
Hi everyone, I have a Orbi Wifi AX6000 with 4 satellites RBS850. One of the satellite is on the 1st floor and is used as relay to the 2nd floor satellite Every night this 1st floor satellite is ...
- Sep 14, 2022
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡I recommend updating FW to v.11 on the RBS first then the RBR.
v.16 had problems.
absolutben wrote:
Hi everyone,
Every night this 1st floor satellite is pulsing white. And it doesn't stop. During the day, it is not doing that.
The firmware is the latest 4.6.3.16 and same as the other ones. Do you know why I have this problem?
Thanks
Benoît
ekhalil
Sep 14, 2022Master
When it's pulsing white, does it show on the Orbi app as disconnected? I assume that all satellites use wireless backhaul?
If so then it seems that the radio conditions get worse during night, likely because of disturbances for some reason.
Do you have the possibility to get the satellite closer to the router or remove obstacles in between to stregthen the signal received by the satellite from the router?
