absolutben
Sep 14, 2022Aspirant
RBS850 Pulsing White At night
Hi everyone, I have a Orbi Wifi AX6000 with 4 satellites RBS850. One of the satellite is on the 1st floor and is used as relay to the 2nd floor satellite Every night this 1st floor satellite is ...
- Sep 14, 2022
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡I recommend updating FW to v.11 on the RBS first then the RBR.
v.16 had problems.
absolutben wrote:
Hi everyone,
Every night this 1st floor satellite is pulsing white. And it doesn't stop. During the day, it is not doing that.
The firmware is the latest 4.6.3.16 and same as the other ones. Do you know why I have this problem?
Thanks
Benoît
absolutben
Sep 23, 2022Aspirant
Thank you very much! Upgrading the firmware really helped. Now it is all working good
thanks
Sep 23, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
