Zrb
Feb 16, 2021Aspirant
Rbs850 reboots every time iPhone connects
So I’ve noticed that whenever my iPhone 12 Pro moves from my rbr in the basement to the rbs in the kitchen the rbs completely shuts down and reboots. Any thoughts?
Feb 16, 2021Guru - Experienced User
What iOS is loaded on the iphone?
Mine isn't doing that...
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. I use channel 1 and 40 here.
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Change CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless SettingsSave settings and reboot the router and satellite(s). I use 40MHz and CTS 64 here.
Zrb
3.2.17.12 was happening on earlier firmwares
ios 14.4, it could not be isolated to iPhone, but when I move from the basement living room to upstairs is when it seems to happen and it's usually when I have my iPhone
2800 sq/ft
distance netween satellites is at least 30 ft (long time lurker)
2.4 channel set to 1 to avoid zig bee overlap with Philips hue
5ghz 48
brick house and well spaced neighbors so minimal interference
no armor
20/40 is enabled because it nets me better speed test results over wireless
cts is 2347 on both bands
im not new to Orbis interface or shortcomings I just don't post on forums as a matter of practice
Bonus it seems like it happens when I switch satellites while streaming something
- FURRYe38Feb 16, 2021Guru - Experienced User
And are RBS using same version of FW as RBR?
- ZrbFeb 16, 2021AspirantClearly I must pass the gate keeping neckbeard.
Yes and yes.
I’ve read all of your posts and I’m sure you’d want the dispersal pattern of my dogs fart to see if it interfered with the wireless backhaul. Seriously what do you do all day? You have a template that you puke out to the Dullards every time someone says anything around here. I’ve done the diagnostics I’m just throwing it out there. At the end of the day I can hotswap satellites to achieve the end goal that I want.- FURRYe38Feb 16, 2021Guru - Experienced User
IF this has been happening on prior versions of FW, possible your system HW is faulty and needs replacing. Something to contact NG support about. The RBS should not do this if any iphone connects.
