Zrb
Feb 16, 2021Aspirant
Rbs850 reboots every time iPhone connects
So I’ve noticed that whenever my iPhone 12 Pro moves from my rbr in the basement to the rbs in the kitchen the rbs completely shuts down and reboots. Any thoughts?
Feb 17, 2021Guru - Experienced User
And are RBS using same version of FW as RBR?
Zrb
Feb 17, 2021Aspirant
Clearly I must pass the gate keeping neckbeard.
Yes and yes.
I’ve read all of your posts and I’m sure you’d want the dispersal pattern of my dogs fart to see if it interfered with the wireless backhaul. Seriously what do you do all day? You have a template that you puke out to the Dullards every time someone says anything around here. I’ve done the diagnostics I’m just throwing it out there. At the end of the day I can hotswap satellites to achieve the end goal that I want.
Yes and yes.
- FURRYe38Feb 17, 2021Guru - Experienced User
IF this has been happening on prior versions of FW, possible your system HW is faulty and needs replacing. Something to contact NG support about. The RBS should not do this if any iphone connects.
