adambloch
Nov 01, 2023Aspirant
RBS850 reconnecting to the internet every 2-3 minutes
RBR850 Firmware VersionV4.6.14.3_2.3.12 GUI Language VersionV3.0.1.54_2.1.30.3 Operation Mode Router We have a our mesh setup and that part works great but we seem to have a problem with the i...
adambloch
Nov 02, 2023Aspirant
Thanks for that advice and it seems to have solved one problem but I now have anew one. The internet seems to be stable and good but the Router and whole network now seems to be dropping out completely. the whole network seems to drop out and disappear. If I try and scan it (Advanced ip) there is nothing there.. it then starts to reappear and will work for 15-30mins and then disappear again. The logs aren't showing anything.
Hardware VersionRBR850
Firmware VersionV7.2.6.21_5.0.20
GUI Language VersionV3.0.3.10_2.1.30.3
Nov 02, 2023Guru - Experienced User
Users can now disable NG from auto updating your system as well. There is a disable check box on the RBRs web page.
