vigraj
Aug 04, 2021Follower
RBS850 satellite compatible with RBK752 - AX4200 router?
Hello all, I'm not able to find an addon satellite for the RBK752 system(AX4200). Can I add the RBS850 satellite to the RBK752 system(AX4200)? Is it compatible? Thanks!
Aug 04, 2021Guru - Experienced User
Yes. Also EAX80 will work as well.
