Blem
Mar 23, 2022Aspirant
RBS850 Satellite dropping wifi connection 10-15 seconds multiple times per day
I bought an RBK853 set plus a separate RBS850 about 10 months ago for my ~10,000 sq ft house. the RBK853 is set up in the main house with the router connected to a Netgear CM2000 modem in bridge mode...
Mar 23, 2022Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Is there a LAN switch in between the RBR and RBS or a wall jack?
What CAT# LAN cable are you using? CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
