Blem
Mar 23, 2022Aspirant
RBS850 Satellite dropping wifi connection 10-15 seconds multiple times per day
I bought an RBK853 set plus a separate RBS850 about 10 months ago for my ~10,000 sq ft house. the RBK853 is set up in the main house with the router connected to a Netgear CM2000 modem in bridge mode...
Blem
i have a Netgear Nighthawk CM2000 Cable Modem that i own. the Orbi RBR850 is connected to this. it is operating in Router mode. i have had this "bad" satellite connected to router with a CAT6 wire and i have also had it connected to a LAN switch and i have had it wireless in the last month and it gives me the same problem all 3 ways. I currently have one of the other RBS850's connected to a LAN switch and am not having any problems. the home is 9500-10000 ft. Auto, but 5Ghz is on 48 and 2.4Ghz is on 6. i have wifi neighbors, but they are pretty far away and they are the same i have had when i had no trouble prior to a month ago and also the same that i have right now with no trouble when this Satellite is unplugged and another is connected to LAN cable.
Blem
I have done a factory reset.
