Blem
Mar 23, 2022Aspirant
RBS850 Satellite dropping wifi connection 10-15 seconds multiple times per day
I bought an RBK853 set plus a separate RBS850 about 10 months ago for my ~10,000 sq ft house. the RBK853 is set up in the main house with the router connected to a Netgear CM2000 modem in bridge mode...
Mar 23, 2022Guru - Experienced User
If you swap RBS locations with each other, does the problem follow the one RBS or remain at this one location?
Seems like if this one RBS is problematic, you may need to contact NG support and ask about RMA options. No FW updates would fix this...
