River25
Feb 21, 2022Tutor
RBS850 Satellite keeps flashing from white to blue, solid blue at random
Hello, I have read countless reddit posts and others about this same issue I'm having but no good answer for a fix, if there is one. For the last few weeks the RBS850 satellite on the 2nd floor of ...
Feb 22, 2022Guru - Experienced User
Try moving the RBS closer to the RBR, 75-100 feet maybe to to far in distance, try 50 feet.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
