HansF
Feb 27, 2021Guide
RBS850 Satellite keeps flashing white (seems to operate correctly)
Since a day or two, the satellite of my Orbi system keeps flashing white. It indicates that it is trying to restore factory reset settings (but what triggered that?) according the docs. Logging int...
- Mar 08, 2021
Glad you got it working. Please mark your thread as solved so others will know. Be sure to make a backup configurtion to file for safe keeping. Saves time if a reset is needed.
Enjoy.
Feb 27, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try updating FW on both RBR and RBS:
Factory reset and setup from scratch.
- HansFMar 08, 2021Guide
It is not about the distance: that is ok (it worked for >=12months) without major issues.
I finally managed to stop the flashing by redoing a firmware upgrade.
It seems that the ability to connect to devices was not affected by this issue.
- FURRYe38Mar 08, 2021Guru - Experienced User
Enjoy.
