HansF
Feb 27, 2021Guide
RBS850 Satellite keeps flashing white (seems to operate correctly)
Since a day or two, the satellite of my Orbi system keeps flashing white. It indicates that it is trying to restore factory reset settings (but what triggered that?) according the docs. Logging int...
- Mar 08, 2021
Glad you got it working. Please mark your thread as solved so others will know. Be sure to make a backup configurtion to file for safe keeping. Saves time if a reset is needed.
Enjoy.
HansF
Mar 08, 2021Guide
It is not about the distance: that is ok (it worked for >=12months) without major issues.
I finally managed to stop the flashing by redoing a firmware upgrade.
It seems that the ability to connect to devices was not affected by this issue.
Mar 08, 2021Guru - Experienced User
Enjoy.
