Norhtstarjoe's avatar
Norhtstarjoe
RBS850 Satellite Not Syncing after power outage
Hello, I purchased a RBR850 with a single satellite (I'll call this Sat 1). I ended up buying another sattelite separately (I'll call this Sat 2), it is the same model, RBS850 and all three devices ...
  • FURRYe38's avatar
    Ok. Sounds good. Ya, thats alot of hassle sometimes. The PW reset should work but I've found that doing a reset and setup from scratch is just the best way to clear anything out. Sometimes odd things get hung up on the system so a reset is needed. Also browser caches can be problematic as well or saved passwords in browsers can cause some problems too.  I try to keep to one router browser I only use for accessing the routers web page and doing FW updates. Then use others for all other general uses.
    Glad you got it working finally. Please mark your post as solved so others will know.
    Enjoy. :smileywink:
