Norhtstarjoe
Dec 28, 2020Aspirant
RBS850 Satellite Not Syncing after power outage
Hello, I purchased a RBR850 with a single satellite (I'll call this Sat 1). I ended up buying another sattelite separately (I'll call this Sat 2), it is the same model, RBS850 and all three devices ...
- Dec 29, 2020
Ok. Sounds good. Ya, thats alot of hassle sometimes. The PW reset should work but I've found that doing a reset and setup from scratch is just the best way to clear anything out. Sometimes odd things get hung up on the system so a reset is needed. Also browser caches can be problematic as well or saved passwords in browsers can cause some problems too. I try to keep to one router browser I only use for accessing the routers web page and doing FW updates. Then use others for all other general uses.
Glad you got it working finally. Please mark your post as solved so others will know.
Enjoy. :smileywink:
Norhtstarjoe
Dec 29, 2020Aspirant
FURRYe38 Thank you for your help. My last resort was doing a reset. I spent several hours this morning doing different things, all to no avail. I then got myself into an issue with the password reset that I could not recover from. At that point I had no choice but to do a factory reset by holding the rest button for 10 seconds.
Thankfully I had saved a config backup last night. Now my Sat 2 seems to be working and it has devices connected to it. With the backup config it was no issue to restore all my previous SSID and password and my devices all connected without me having to do anything manual or time consuming.
Wow! What a lot of time spent on this. I was about ready to ditch my RBR850 system and go buy a new 3 pack from Costco when I had my password problem.
Dec 29, 2020Guru - Experienced User
Enjoy. :smileywink:
