rgpinrr
Aug 23, 2022Aspirant
RBS850 Satellite Showing - Backhaul out of sync - Implications?
Both my RBS850 satellites (one wired backhaul, one wireless) are showing backhaul status as "Out of sync". All nodes show v4.6.8.2 with no newer available. Devices are attached to nodes and seem to be working, so not sure what this means and why it is showing this way?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.What happens if you turn OFF all but this one RBS?
Can you access this one RBS web page at it's IP address seen on the RBR?
- rgpinrrAspirantI wasn’t completely clear. I have RBR850 router and two RBS850 satellites. The RBS850 running wired backhaul is about 40 ft from the RBR and the RBS850 running wireless backhaul is about 30 Dr from the RBR. I am successfully getting internet from devices connect to any node. I have transmission power at 50%. At 100% everything wants to connect to RBR and stay connected there.
All functions appear to work, but backhaul status for both RBSes show as “out of sync”.- FURRYe38Guru - Experienced User
Try connecting both RBS using wireless backhaul instead of ethernet.
Has a full factory reset and setup from scratch been performed since last FW update?
