dcraig
Mar 15, 2020Guide
RBS850 Satellite will not sync with RBR850 Router when in AP mode
Hi, Is anyone else having a problem with wireless syncing a RBS850 satellite with a RBR850 router when the router is in AP mode? If I physically plug the RBS850 satellite into the network with e...
Mar 15, 2020Guru - Experienced User
Remove the RBS from the RBRs connected clients page. Factory reset the RBS then when it's slowly blinking WHITE, Press the sync button on the RBR then RBS. Do this while you have the RBS in the same room as the RBR.
Seen no issues with wireless when in AP mode.
