wagnermba
May 21, 2022Guide
RBS850 Satellite Won't Connect
After a recent power outage, my Orbi RBR750 fired up fine (as did gateway) and provides wireless coverage as before. However, my two RBS750 satellites will not show up as connected (in app or on bro...
- May 29, 2022
Solved! Or should say resolved. Found both satellites had upgraded their firmware. Set them back to match the router. Then, they started showing up on the web page in a room near the router. After moving them back to the places they had been before, one showed up fine and was in synch. The other was out of sync, but hitting the back of the satellite and the router synced them back up. Fingers crossed this stays "as is" for a while. Thanks for the help Netgear Community!
Mikey94025
May 21, 2022Hero
wagnermba wrote:With all of the above, they turn on, flash white, then go to solid blue for a couple minutes before the light goes off. But, I can't see them in app or on the browser as connected devices.
Note that solid blue than turning off is the normal operation per https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean:
Solid blue. If your Orbi satellite ring is solid blue for 90-180 seconds, the connection between your Orbi router and satellite is good.
What does your orbilogin.com admin website show for the satellites under Basic / Attached Devices / Connected Satellites? If you wire connect something to a satellite, does it get an IP address and is it connected to the internet?
If all else fails, try factory resetting your Orbi router as well as the satellites, and add them back again: https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
wagnermba
May 28, 2022Guide
Hi: Thanks for your reply. The solid blue made me confident as well.
Believe it or not, having left both of the satellites plugged in, this morning I show both of them on my network map on the Orbi app and on the network map on the website. Oddly, one shows its connection via 5G, the other as wired (neither hare hardwired) and the website says both are "out of sync" for their backhaul status. Guess I need to research that!
Nether show connected devices on the Orbi app, which may be due to the backhaul status synching?
Welcome further advice!
