msinex
Aug 13, 2022Apprentice
RBS850 Satellite Won't Reset and in Continuous Reboot
I have a satellite that seems to be in constant reboot (it will flash white lights for a few minutes, then go to solid blue for a few minutes, then go off, only to go back to flashing white about 5-1...
- Aug 14, 2022
Did you try removing the one disconnected RBS from the RBRs web page, reboot the RBR then onces it's back to ready, press the sync button on the RBS and RBS while the RBS is in same room as the RBR? I would turn OFF the other RBS before you do this.
Aug 14, 2022Guru - Experienced User
What FW is loaded on the system? Same as RBS as on RBR?
Can you connect the RBS via ethernet to the back of the RBR?
- msinexAug 14, 2022Apprentice
Thanks for the response!
Same firmware on router and both satellites. The other satellite seems to be working just fine. FW is 4.6.8.2 I actually did have this satellite working on a ethernet connection up in it's typical place, and when it started having issues I took the ethernet out thinking maybe that was the issue. Now that I have it close to the router I have it off ethernet.
- FURRYe38Aug 14, 2022Guru - Experienced User
Thanks Furry. How do I remove the Satellite from the webpage? I did try to resync them in the same room, but didn't turn off the other Satellite. I can do that once you can let me know how to remove the broken one.
