msinex
Aug 13, 2022Apprentice
RBS850 Satellite Won't Reset and in Continuous Reboot
I have a satellite that seems to be in constant reboot (it will flash white lights for a few minutes, then go to solid blue for a few minutes, then go off, only to go back to flashing white about 5-1...
- Aug 14, 2022
Did you try removing the one disconnected RBS from the RBRs web page, reboot the RBR then onces it's back to ready, press the sync button on the RBS and RBS while the RBS is in same room as the RBR? I would turn OFF the other RBS before you do this.
msinex
Sep 05, 2022Apprentice
I took these steps and it seemed to work better for a few days, but is unfortunately now back into the reboot cycle like it was before. Any thoughts? Thanks for all the help!
