marshall2553
Jan 27, 2022Aspirant
RBS850 Satellites bricked after downgrading from 4.6.7.5
I installed 4.6.7.5 but was having issues with dropped connections and occasional satellite reboots. I downloaded 4.6.3.16 from the support page and manually downgraded the satellites followed by th...
KMDonlon
Jan 27, 2022Virtuoso
This worked for me:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
- marshall2553Jan 27, 2022Aspirant
KMDonlon wrote:
This worked for me:
Thanks, that was going to be my next step if nothing else works. I'm kind of hesitant to attempt to update the firmware when it is rebooting every few minutes, though.I tried hardwiring a satellite to the router, same result. It is getting an IP and I can occasionally pull up the admin page, but it reboots before I can do anything.
- plemansJan 27, 2022Guru - Experienced User
plemans wrote:nmrpflash can sometimes be easier to use.
https://github.com/jclehner/nmrpflash
Thanks, I'll give that a try this afternoon. Following NetGear's instructions for TFTP did not work, I just get a "Connect request failed" error. I was watching the status of my PC's ethernet connection to the satellite while attempting the update and it alternated between connected and not connected, so I'm not sure it's staying up long enough to even perform an update.
