NorbertNJ
Aug 08, 2021Aspirant
RBS850 Satellites Connection Issues
My two RBS850 satellites keep disconnecting from my RBR850 router and even if they are connected to the router they have most of the time no devices connected, so all devices are connected to the rou...
Aug 08, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Turn OFF one of the RBS and see if the other RBS remains ONLINE...
Has a factory reset been performed and setup from scratch?
- NorbertNJAug 16, 2021Aspirant
Hi, thanks for your response. Here are some answers:
Firmware:V3.2.18.1
I am connected to a Comcast XFi Gateway Modem: https://www.xfinity.com/learn/internet-service/modems-and-routers?CMP=KNC-43700053503843974-GOOGLE-251733430034-c-comcast%20xfinity%20xfi%20gateway-e-Xfi_BR_Exact_North&gclid=CjwKCAjwmeiIBhA6EiwA-uaeFWLctoBcYvEgoGn0EofC58AvHlzn5cVbZKlgEBNdiPWbtvzKT2IMQxoC_O4QAvD_BwE&gclsrc=aw.ds
My home is about 3500 SF
The distance between RBR and RBS was about 20 feet. After reading your response I increased it to over 30 feet and it improved the situation, so more devices now connect to the satellites!
When I turn off one RBS the other RBS stays online.
I have not done a factory reset yet. I am trying to avoid to have to do that and go through the entire setup process again. Do you think I still have to do this?
Is my firmware the latest version?
Thanks so much for your help!
- FURRYe38Aug 16, 2021Guru - Experienced User
Firmware:V3.2.18.1
What mode is this modem working in? Router or in modem only? This modem has a built in router and wifi already.
When I turn off one RBS the other RBS stays online. Lets leave the 2nd RBS OFF and see how the system does for you.
Is my firmware the latest version? No yet. Let leave it for now.
- NorbertNJAug 21, 2021AspirantThanks, I left one of the two RBS off and the remaining RBR and RBS were doing fine.
Also putting back on both RBS works fine now, so I think positioning them further away from the RBR solved the problem.
Just one question: is my firmware V3.2.18.1 the latest or do I need a firmware update?
Thanks for all your help. All the best!
