Jonwoo
Apr 26, 2022Aspirant
RBS850 v4.6.7.13 firmware update issue
Hi, I have an RBR850 with two RBS850 satellites. I have manually updated the first satellite to v4.6.7.13 but it will not connect back to the router after the update. I have tried synching se...
- Apr 26, 2022
So when you updated the RBS first and let them process the update, then did you update the RBR lastly and let it process the update. Then turn OFF the RBS and RBR for 1 minute then back on with the RBR first then RBS?
Try connecting the RBS to the back of the RBR via ethernet cable...
Apr 26, 2022Guru - Experienced User
Jonwoo
Thank you for the suggestion.
Based on your post I took a leap of faith and upgraded the second satellite to the new firmware version which reconnected to the router straight away.
After I updated the router firmware as well the second problem satellite reconnected as well so all up and running now.
Thank you for the help.
- FURRYe38Apr 26, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
