Jonwoo's avatar
Jonwoo
RBS850 v4.6.7.13 firmware update issue
Hi,   I have an RBR850 with two RBS850 satellites.   I have manually updated the first satellite to v4.6.7.13 but it will not connect back to the router after the update. I have tried synching se...
  • FURRYe38's avatar
    Apr 26, 2022
    So when you updated the RBS first and let them process the update, then did you update the RBR lastly and let it process the update. Then turn OFF the RBS and RBR for 1 minute then back on with the RBR first then RBS?
    Try connecting the RBS to the back of the RBR via ethernet cable...
